Is it possible to convert SOLID WORKS file to dwg?
Hello,
I am now trying to open a Solid works model file (attached) in an old version (2003) of AutoCAD - dwg format. Can anyone please advise/ assist me if it is possible to do so.
Many thanks in advanced,
U
Yes. Save your model in .iges or .step and then open autocad -> go to "import" and select the file .step or .iges . When the importation process is finished the draw will set up in the autocad screen. Save it in .dwg and you get it!
Thanks !
