Hello,
i want to print one object in two colors, the gradient should be clear defined.
Is it possible to define the gradient with the Grab Cad print software?
The object is a dental prosthesis with pink and white color.
Printer: Stratasys J5
Thank you :)
You need to turn off the extruder flush when changing colors and then the gradient will be smooth.
