Parallel blend in Pro/E
Can i make parallel blend in two different objects without same entities???
if it is possible,how can i make it???
yes. as of my knowledge by adding datum points u need to make the entities equal in number .
eg) one circle and square, place four datum points on the circle.
s you can, draw the section of first object, say its no of entities was 5. and then toggle the section then draw the second section but make sure the no of entities was lesser or equal than first one, then in second section click one of the entities and right click in it then apply blend vertex. then u can blend those objects
