parent child in pro-e
how can i delete a parent child relationship?
if i have done a component with 3 parts suppose top middle bottom
say if i have done middle i have taken reference from bottom and top reference from middle so how can i delete this.....(I HAVE DONE THIS ON ASSEMBLY)
You would need to restructure your assembly but it would most likely need to be redrawn/suspended. Also there is a dirty trick with its pros and cons. You can take your parts of your assembly and export them as .STP files and reimport them in the order you wish. Be advised this is a last resort and you will no longer have model tree for those parts. Last resort only! I would expect if you only have 3 parts that you could get it fixed. Let me know if you need further help.
