Solid edge and Solid work, which one is better?
10 Answer
Solidwork reduce the number of clicks regardless of the system being used. Customize menus to speed things up as needed.
Solidedge has too much keybindings, to much reliance on the keyboard and that slows progress down.
I will go for Solidworks.
Question of the month?
https://grabcad.com/questions/solid-edge-and-solid-work-which-one-is-better
If you're a SWorks user, you might want to download a trial of SEdge to evaluate. Generally, whatever you're most familiar with is the "best"... so I don't know that you're going to find too many objective comparisons forthcoming here. Most of the answers only demonstrate a lack of knowledge about the less favored product...
they do the same things
perhaps with SE you make more clicks but SE has Convergent Modeling,mesh and b-rep modeling together
