Solidworks/Assembly/Assembly feautures tools
How to save a part when we applying seperate command in solidworks assembly (For example if i need a hole for my part and i am using extruded cut tool but at the same time if i opening the same part seperately that hole is not there(i.eextrude cut command is not there)......Kindly give some solution if any one faced the same problem....?
IN your extrude cut feature, tick the "Propagate feature to parts" this will ensure the extrude cut filters through to the part.
