Sweep with two guide curves
Hello, the profile I want to sweep is a line lying on a tyre. I made two parallel curves starting from its two extremities wrapping around the tyre at an angle so the ending and origin don't coincide.
The "with two guide curves" seems to be the most relevant but I need to specify anchor points and I just can't make those work. What anchor points do I use?
