I`m trying to bring in a solid works file from grabcad into solid works to make a solid works drawing of it. I have tried to download the assembly file but when it appears on solid works it breaks up after 10 seconds saying it cant locate the file. Am I doing something wrong?
SolidWorks assemblies must be accompanied by all of the part files the are in it. If the designer did not upload the part files for the assembly you will not be able to open it. You should contact the designer to see if they will provide the necessary files you need.
