Tutorial: How to convert spline into a lines and arcs?
For Circle spline.
Answered with a tutorial: https://grabcad.com/tutorials/tutorial-how-to-convert-spline-into-a-lines-and-arcs
Another option but in this case I will convert randomly shape splines
Answered with a tutorial: https://grabcad.com/tutorials/tutorial-how-to-convert-spline-into-a-lines-and-arcs--1
u can write amunspline in command bar then select spline after this u most select another point on screen then spline covert to straight line.
mot: u can use this command in CAD software bout i dont know u can use this command in another software or not.
1. create a contour toolpath using the spline and use the toolpath arc filtering to fit arcs and lines. (compensation set to "Off")
2 You now need to change the toolpath to geometry from the Backplot menu
using the "Save as geometry" button
if i don't forget answer u can use command : Amunspline to convert spline and arc to line and use ..... to convert line to spline
hello master-cam users;
i have a problem in master-cam mill/turn,.
can anybody please help me please?
http://grabcad.com/questions/how-can-i-make-a-c-axis-turning-mill-turn-program-in-master-cam
