Tutorial - How To Make a Simple Spring In Solid Edge
This is the tutorial
Answered with a tutorial: https://grabcad.com/tutorials/tutorial-how-to-make-a-simple-spring-in-solid-edge
You can make an adjustable spring as well! Really easy: http://www.youtube.com/watch?v=jcjkbi95uGs&feature=c4-overview-vl&list=PLB83C34F04B96C23C
There is also a Compression Spring Designer and an Extension Spring Designer in the Engineering References. I am not sure if that feature is included in every version though.
Here is a tutorial for Compression and Extension Spring
Must Check Out
https://www.youtube.com/watch?v=B7HVP8XB_c4&feature=youtu.be
