Tutorial: how to make standard compliant sections in Solid Edge Draft
The ISO 128-44 standard defines the rules for the representation of sections in mechanical drawings. Section 4 of this standard states: normally, ribs, connection elements, shafts, spokes and similar elements must not be sectioned and along the longitudinal direction. By using the normal section command it is not always evident how to get the result required by the standard.
This tutorial show how to produce standard compliant sections with the Draft module of Solid Edge.
Answered with a tutorial: https://grabcad.com/tutorials/tutorial-how-to-make-standard-compliant-sections-in-solid-edge-draft
