Tutorial: how to model spring ( using sweep feature) in solidworks (springs are usefull right? this method saves time)
one uses helix, other uses sweep revolve,, both have wire dia of 0.5 in, and total dia of 2 in,,,, one has build time of 0.14 sec, other has 26% more i.e. 0.19 sec, so always use sweep revolve to create springs! unless absolute necessary don't use helix! in small assembly rebuild time does not matter, but for larger ones, rebuild time can be very large! :) cheers!
video link: http://youtu.be/F3m5gHaOqzQ
model: Tutorial: how to model spring ( using sweep feature) in solidworks (springs are usefull right? this method saves time)
files: Tutorial: Spring, Sweep, Feature Statistics, SolidWorks
Hi, use this Persian Tutorial to learn the method of spring modeling. there is no need to read the Persian text. just use the photos and attention to continue it step by step.
