Tutorial -Tips on solid edge
HOw to copy of rotating lines at angles easily in solid edge?
3 Answer
I think your question is not clear.
If I understood what you mean, then here is my answer.
You can use Rotate by step to do it. Under rotate=> Step=> enter necessary angle.
