visualization problem in NX
Hello, I am a ME major working on a project at home on my lab top. Solid bodies are not showing up correctly. The best way to explain is with a couple pictures. This is just a simple shape I extruded to illustrate the problem. Any insight on fixing the issue would be much appreciated.
2 Answer
Yeh this problem is there in NX ...JUST PRESS CTRL+F
fit the model on screen
I got solution for this problem .
it's very simple . for that go on below path
VIEW > CAMERA >EDIT after EDIT CAMERA Dialogue box will open and in this click a Fit Planes to Extents after part will be showing a clear
