Hi guys,
Can anybody explain the use of Invert orientation?
Can we use invert orientation instead of Extract surface?
I am not able to understand the real intention of the tool invert orientation.Please explain me.
Thanks in Advance
Vinoth
Invert does invert the normal vector of the surface,
Example, you have a surface, and you split a body whit it, if you do the split with the invert of this surface you will becom the split on the other side.
But you can use it for much more, it is very helpful in tool design etc...
