2S Petrol engine case using Catia
This tutorial is about how to model a 2S petrol engine case using Catia V5. This tutorial consists step by step procedure.
Step 1: Creating an engine case
Open Catia V5 and click Start > Mechanical Design > Sketcher.
Create sketch as shown below with given dimensions of 20 X 40 mm by selecting a plane and then click OK.
Exit from the sketcher environment by clicking the exit workbench icon.
Click on the pad option and extrude the selected sketch up to 3.5 mm.
Select the face marked and click Reference elements > Plane.
Create a Datum plane as shown above by entering the offset distance of 3 mm.
Create the sketch as shown below in the newly created DTM1 plane and click OK.
Pad (Extrude) the Circle created in previous step to the depth value of 25.5 mm.
Select the top face of the rectangle and create sketch as shown below with specified dimensions and click OK.
Note: Use references tools in Profile group to make it simple.
Pad the previous created sketch with extrude depth value of 25 mm.
Step 11:
Select the face shown below and create a sketch with specified dimensions and click OK.
Step 12:
Create a pad as shown below with extrude depth of 14 mm.
Step 13:
Create sketch below with specified dimension by selecting the face as selected below.
Step 14:
Pad the sketch created in previous step with depth value of 6 mm.
Step 15:
Create fillets as shown below by selecting the edges with radius of 2 mm and click OK.
Create another fillet on the edge selected before with radius of 1 mm.
Step 16:
Create the sketch as shown below by selecting the mid plane with specified dimensions.
Note: Use Oriented Rectangle at 70 degrees from the axis with 7 X 14 mm dimension (use construction lines to make it simple)
Step 17:
Create a revolve section as shown below with reference the axis and click OK.
Step 18:
Create sketch as shown below with specified dimensions at the selected faces and pad backwards with a depth value of 8 mm.
Step 19:
Pattern the extruded part using Circular pattern taking instances as 4.
Step 20:
Create the sketches as shown below using 3D project options and using dimension constraints and create pad up to selected edges as show in images.
Step 21:
Create fillets with specified dimension r = 4 mm as shown below.
Create fillets at this selected edge with r =1 mm.
Perform fillet as shown below at the selected edges with radius of 3 mm.
Step 22:
Create fillets as shown below with specified dimensions on the selected edges with r =2 mm.
Create fillets r =2.5 mm at the selected edges as shown below.
Step 23:
Create sketch as shown below and pad to a depth value of 9 mm.
Step 24:
Create the sketch on the same face which you created sketch in the previous step with specified dimensions and create a pad with depth value of 1 mm.
Step 25:
Pattern the extruded part using Rectangular pattern taking instances as 4 with a spacing of 3 mm.
Step 26:
Create Edge fillets on the selected edges with a radius of 2 mm.
Step 27:
Create a sketch as shown below with the help of 3D projection.
Step 28:
Create a pad selecting the above sketch up to 9 mm.
Step 29:
Select the above extruded part and pattern it using a Circular pattern.
Step 30:
Create fillets as shown below with r =0.3 mm.
Create another set of fillets at the selected sections as shown below with r =0.5.
Step 31:
Create a plane as shown below.
Step 32:
Create a sketch as shown below with the help of projections. Take the width of Rectangle as 2 mm.
Step 33:
Pad the created sketch in reverse direction with a depth of 12 mm.
Step 34:
Create fillet for the selected edges with a radius of 0.5 mm.
Create fillet for the selected edges with a radius of 1 mm.
Step 35:
Create sketch as shown below with specified dimensions and remove material using pocket option also create circular pattern of the holes.
Step 36:
Create sketch at the selected faces as shown below.
Now using Pocket remove material with a depth of 25 mm.
Step 37:
Pad the selected sketch up to 0.25 mm.
Step 38:
Create fillet for the selected edges with a radius of 0.3 mm.
Step 39:
Create a plane at an offset distance of 2 mm as shown below.
Step 40:
Pad the sketch up to 1 mm downwards and pattern the part using rectangular pattern.
Mirror the pattern to the opposite side as shown in the figure.
Step 41:
Create fillets for the extruded parts with r = 0.3 mm.
Step 42:
Create a sketch as shown below.
Using Pocket remove material up to 4 mm.
Step 43:
Create a sketch on the selected face and pocket it using up to last option.
Step 44:
Create a sketch and pocket the face with a dimension up to 20 mm.
Step 45:
Create a sketch as shown below, using pocket remove material up to a depth of 9 mm and pattern that using Circular pattern as shown below.
Step 46:
Create fillets to the patterned holes with a radius of 0.3 mm.
Step 47:
Create a sketch and Pad it up to 14 mm equally on both sides.
Step 48:
Create a sketch as shown below and pocket using up to last.
Step 49:
Create fillets for the selected edges with a radius of 0.3 mm.
Step 50:
Create a sketch as shown below and pocket it up to 15 mm.
Step 51:
Create a sketch as shown below using mirror option and remove material using pocket.
Step 52:
Create a sketch as shown below and pad it up to 7 mm.
Step 53:
Create fillets for the selected edges with a radius of 0.5 mm.
Step 54:
The final component looks like this.
