Altium Designer Tutorial 12 : How to add Parameters to Multiple Components in Altium Designer 21 Integrated Library.
#Adding #Parameters to #Multiple #Components in #altiumdesigner #integrated #library
#Parameter #table #editor #altiumdesigner designer
#components #parameters
Adding Parameters to Multiple Components in integrated Library Altium Designer
Parameters are a key element of each component, and it is common for many of the parameters to be used across multiple components. As well as adding them individually to each component, you can also use the Parameter Manager command (Tools » Parameter Manager) to add them to multiple components. As well as adding or removing parameters, the values of parameters can also be edited across multiple components.
  1. Step 1: How to add Parameters to Multiple Components in Altium Designer 21 Integrated Library.
