Altium Designer Tutorial 20: Adding THT Connector Component classes & Design rule for Polygon.
Through hole terminal connector Component classes & Design rule for Polygon.
0:00 Introduction about Classes & Design Rule
1:05 How to Pour Polygon?
3:20 Define "Classes for THT Connector"
4:30 Define "Design Rules for THT Connector classes"
6:35 THT Connector PAD direct connect in GND Polygon
Object classes for the active PCB document can be browsed and managed from two key locations:
The #classes region of the relevant mode of the #PCB panel (Design - Classes). From here you can add a new user-defined class (right-click, then choose Add Class), or edit the membership of an existing user-defined class (double-click or right-click, then choose Properties). The name of the class and its members are defined in the corresponding Edit Class dialog.
You can only add and edit user-defined classes. The default system classes cannot be edited.
PAD Classes: https://youtu.be/ndEb73tA8qc
#Component #classes in #altiumdesigner
#Designrule #altiumdesigner
#componentclasses
#Altium
#PCBdesign
#Designrules
#PCB Rules
#customquery in Altium Designer PCB
#InPADClass
#isvia
#custom query polygon
#InComponentclass
How to #Connect #Polygons to #nets in #altiumdesigner
#Pourpolygon
#polygon
