Assembly in PTC Creo
How to assemble parts in PTC Creo.
Step 1: Open a new file
- Open a new file and select assembly.
- Then select design.
- Select the required template.
Step 2: Assembling the base Component
- Click on the Assembly tab and open the required part model from the file location you have saved your part model.
- After selecting the desired component apply the constraint as default.
- Click OK.
Step 3: Assemble all the parts
- Again click on assemble.
- Open the desired 3D part model.
- Then apply the constraint as coincident by selecting the two surfaces to be coincident.
- Apply all the constraints that needed to be define.
- Apply the constraints until it is fully constrained
- Click OK.
Step 4: Repeat the procedure
- Repeat all the procedure until all the components are assembled.
Step 5: Save the file
- Once all the parts are assembled save the file.
