CATIA V5 - Reverse Engineering (Curve from 3D scan)
This is an overview of the reverse engineering workflow in CATIA V5.
Step 1: Planar section into Curve from 3D scan
3D model used within the case study available at:
https://www.artec3d.com/3d-models/motorcycle-crankcase
The workflow converts Planar sections into curves from scan which can then later be used within a wide variety of workbenches.
