Change Sketchup Shortcut
how to change sketchup shortcut
Shortcuts are program commands that are called by pressing the keyboard keys simultaneously. Usually a combination of ctrl, alt or shift combined with numbers or letters.
In the Sketchup program, shortcut features have been provided simply and automatically. The Sketchup shortcut is a letter on the keyboard which when pressed will display the menu/tool in question.
This sketchup shortcut can be replaced and customized according to user convenience. So if you want to change the Sketchup shortcut, please follow the tutorial below
> Open your Sketchup program
> After that click Windows then select Preferences
> The next step is to click the Shortcuts menu, then look for the shortcut button you want to replace via the Filter column
>At this stage you can add a new shortcut by clicking the Add Shortcut column, then fill it with a new shortcut of your choice. For example here I replace it with the letter G then click the plus button (+)
Yep, you have successfully replaced the Sketchup shortcut. The next step you can try the new shortcut. If the keyboard command doesn't work please restart it first
