Create a spring with FreeCAD
a step by step tutorial for creating a spring with the open source program FreeCAD
Open a new File in the Part workbench.
Click on create primitives and choose "Helix".
Now, we set the height to 10mm
and the radius to 2.4mm
and click the "Create" Button.
And now, we have a helix with 10 turns.
We change to the Part-Design workbench and create a new Body.
We select the Helix and create a shape-binder.
We hide the Original Helix and see a yellow shape-binder helix.
We take the front view and create a new sketch on the XZ-plane.
We activate the helix in our sketch with the "external geometry" button.
we draw a circle with a radius of 0.4mm at the green point of the helix.
close the sketcher window
now, select click at first the circle and then the helix-shape-binder with ctrl.
Press "additive pipe" button and see what will happened.
A Helix!!! Congrats...
And now, we need an end of the helix.
Open a new sketch on the YZ-plane.
On the upper end, we have to make a vertical cut.
- We change the draw style to "wireframe"
- we take the end circle with "external geometry" (ctrl + x)
- an draw a rectangle like this.
- it is important that the rectangle completely overlaps the end.
- change the view to normal and close the sktech.
- Press the pocket button.
- Change Type to "Trough all"
- Activate reversed
- Press OK
At the next step, we finish ou helix with two steps.
Step 8: Finish
This step is actually one step, which we make two times.
Which page you want to do first, you decide for yourself.
I take the upper side.
- Select the vertical end of the helix and...
- Click the "Revolution" button
- Change the axis to "Base Z axis"
- Press OK
and repeat this step on the other side.
Congratulation!!! Well done...
Your first helix !!!
If you have any question, write me a message.
