How to create a spring with surface
Small
This is a spring tutorial with surface
    Select the front plane,and draw a vertical line according to picture and close the sketch
    Now open the front plane and draw a line at the length of the radius of helix
    Select the sweep surface,and set the horizontal line as the profile, and the vertical line as the path (set option according to picture) and then close the sketch
    Now open the 3D sketch, and used convert entities on the edge according to picture
  5. Step 5:
    You can see the 3D sketch on the edge according to picture,now close the sketch
  6. Step 6:
    Go to Insert > Reference Geometry > Plane or click at the Plane icon
    Select the Endpoint of the Spline as First Reference
    Select the Spline itself as Second Reference
    Click OK
  7. Step 7:
    Select the new Plane in the feature tree and create a sketch according to picture
  8. Step 8:
    Now open the sweep and select the circle sketch as the profile, and the 3dsketch as the path (notice to picture)
  9. Step 9:
    Now hide the solid bodies,I hope you’ve learned something about the create a spring with surface
Please log in to add comments
