Fusion 360 Tutorial: Create a Detailed Bolt with Threads!
Welcome to DesignEngineered! In this detailed tutorial, I will guide you through creating a realistic bolt in Autodesk Fusion 360. Bolts are essential components in many mechanical assemblies, and mastering how to model them accurately is crucial for any CAD designer.
In this video, you'll learn:
Start a new sketch and draw a hexagonal head for your bolt.
The extrusion process gives your bolt a solid shape.
Creating a circular shaft with specific dimensions (diameter: 6 mm, length: 30 mm).
Adding realistic threads using the Thread feature in Fusion 360.
Software: Autodesk Fusion 360
Dimensions: Hexagonal head (20 mm diameter, 5 mm thickness), Shaft (6 mm diameter, 30 mm length)
