Hi ,how do I change units permanently in SW ,set mine up in Metres and meant to use
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/missing_feed.png)
![](https://d2t1xqejof9utc.cloudfront.net/pictures/files/32667/small.png?1390738732)
Tutorial
Open a New Part File in Solidworks
Now click on Options
Now check under Document Properties & click on Units
Now change the default Unit system to your desired unit system -
Next step is to click on Save button
Now change the file Save As Type to Part Templates
Now click on the Original Template File & press Save
So now you have permanently changed your Unit system
Note that the similar procedure is also appicable to Assembly and Drawing Files...
