How do I taper a coil in Inventor?
Tapering a Coil.
Create a 3d sketch and make a coil
Create a plane on one end
Create a sketch on that plane, using the geometry from the coil
Use the sweep tool with a negative angle.
It should result in a tip. -
There you have it. Hope it helps.
