How i can remove flexes in a curve in catia V5? (smooting command do not help)
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/missing_feed.png)
Have you tried smooth curve with curvate parameter turned on? It usally removes most of the vertexes. With G2 constant curve you should easily sweep the profile along direction.
