How to Control Objects with Layer in Siemens NX
When You Have a small number of object, you can manage the objects by using the Show & Hide command. However, when modeling required a huge number of object to be managed on the screen, the show and hide command is not sufficient.in this case, you will use the layers.
https://youtu.be/9bq9swwpjS4
