how to convert files from MapSource GDB to Autocad DXF
I will give a tutorial in viewing the map in MapSource and convert to autocad ..
find the map you need, here I am using MapSource ..
save as to the DXF file extension
This setting is important ... easy things you can use UTM coordinates ..
but here I am using "use decimal degrees"
and klik OK
then you can open the AutoCAD application, here I am using AutoCAD 2010, and then open - type DXF - I used the "select initial view" - open
then this screen will appear, select OK
This is a result that I can and stay in the edit ...
and the map in autocad I get from MapSource software ..I hope this can help ..
