How to create a script in AutoCAD?
Missing small
If you want to automate repetitive tasks, then you should use scripts.
Scripts are instructions executed by computer which could alternatively be executed one by one, by a human operator.
    Creating a script is actually a simple action which imply to create a set of instructions that are exceuted automatically by a script interpreter.
    These instructions can be executed within any text editor, such as Notepad.
    AutoCAD commands that normally you would execute one by one are written in the text file as lines.
    Let’s make a simple script that creates automatically three UCS’s: Front, Top and Right.
    Note!
    Comments can also be included in the script file.The lines that contains the ‘;’ sign are interpreted as comments.
    Just type into Notepad these sets of instructions or copy&paste them from this webpage.
    ;This is a comment. ;
    ;Comments will not be interpreted by application. ;
    _-view ;This it’s the first command that will be interpreted
    Front ;Set the view to Front
    UCS ;Starts the User Coordinate System command
    na ;NAmed option
    s ;Save the UCS…
    Front ;… with the name ‘Front’
    _-view ;Starts the view command…
    Top ;…and sets the view to Top
    UCS ;Same steps as above!
    na
    s
    Top
    _-view
    Right
    UCS
    na
    s
    Right ;The last view is named ‘Right’
  5. Step 5:
    Note!
    Don’t forget to save the file with the .scr extension!
    Type 'scr' at the command line if you want to run a script!
Please log in to add comments
