how to create cam follower mechanism
Tutorial by Srijith.M.R.Nair
Small
follow the steps as below
    Open a new assembly in creo
    Create an axis between top and front plane
    import the cam part that must have a modle axis and give pin connection
    also the cam should have a mid sketch as a path curve
  5. Step 5:
    make a new perpendicular axis with the cams axis within the assembly file
  6. Step 6:
    select the follower note that it should have a datum point at the end
  7. Step 7:
    provide a slot connection between the entire curve on the cam and the datum point on the follower
  8. Step 8:
    provide the slider constrain between the perpendicular axis of the cam and the right assembly plane
  9. Step 9:
    all done now go for mechanism module from the application menu
  10. Step 10:
    select the servo motor and select the motion axis of the cam
  11. Step 11:
    go for profile tab and select velocity and give some value for the speed of rotation of the cam
  12. Step 12:
    now go for mechanism analysis and provide the time frame
  13. Step 13:
    and then select run and have a preview and click ok
  14. Step 14:
    now go for playback and select analysis and can see the speed ans then you can capture the video in mpeg format
  15. Step 15:
    to start the animation click on play button and you can adjust the speed also
  16. Step 16:
    ALL THE BEST
Please log in to add comments
  • Missing feed
    Ilton Soares Mozart
    Does anybody know some book that teaches how to create and how to scale out a cam mechanism project?
    October 3rd, 2017 12:27
