How to create Spur Gear in fusion 360
How can we create fusion 360 in fusion 360.
Terminology used for gear are as follows
Module(m) =PCD/No. of teeth=10
No of teeth(N) =26
Addendum(add) = 10 mm
Dedendum (Ded)= 1.125XADD=11.25
PCD = m X no. of teeth = 10X26=260
Outside dia= PCD+2Xadd = 260+20 =280mm
Inside dia = PCD -2 X Ded = 260 -2 X11.25= 237.5 mm
Circular pitch = π X PCD /N = π X 260/26=31.4mm
Tooth thickness = CP/2= 31.4/2 = 15.7 mm
Pressure Angle = 20 degree
    Follow all the step one by one as per the video. after completion of this video you are able to create any type of spur gear.
