How to design a Spline shaft in Solidworks | Solidworks Tutorial
In this Solidworks tutorial, you will learn how to design a Spline shaft in Solidworks. First, you will add material to the 3D model and create the spline shaft shape. Then, you will add a radius feature to the end of the spline shaft and save your file. Finally, you willimensional the spline shaft using the GoTo command and close the document.
https://youtu.be/VYYJXWJND7M
SolidWorks Command Manager Features Toolbar
1. Extrude Boss/Base, which enables to convert a 2D sketch into 3D model. ...
2. Revolve Boss/Base..
3. Swept Boss/Base ...
4. Loft Boss/Base ...
5. Boundary Boss/Base ...
6. Extrude Cut ...
7. Revolved Cut ...
8. Loft Cut ...
9. Smart Dimensions...
Following topic we will covering or other too.
- Solidworks CAD Tutorials for Beginners
- Solidworks CAD 3D Modeling Tutorials for Beginners
- Solidworks CAD House Floor Plan, Elevation & Cross Section Tutorial
- Solidworks CAD 3D House Modeling Tutorial
- SolidWorks Tutorial for Beginners
- Standard Notation
- Create all features in model.
- Add required views of ISO & GD&T
- General Notes
#solidworks
#Solidworkstutorial
#cadcam
#solidworkssheetmetal
#cadcamtutorials
#solidworksweldments
#solidworksdrawing
#solidworkstutorialforbeginners
#solidworksassembly
#cadtutorials
#engineering
Instagram link:
https://instagram.com/solidworkstutorial531?igshid=ZDdkNTZiNTM=
Facebook link:
https://www.facebook.com/cadtutorials?mibextid=ZbWKwL
THANKS FOR SUBSCRIBE MY CHANNEL....
Step 1: How to design a Spline shaft in Solidworks | Solidworks Tutorial
