how to draw gear
its so simple..:)
extrude circle and again sketch the front plane with teeth...
the teeth required is being patterned using axis pattern...and calculated as 360/no.of teeth required
teeth is obtained and insert option is dragged to top of the model tree
then extrude the feature surface as sketching plane and draw a oval block
extrude this up to end of surface and remove material
pattern with axis
select surface extrude by drawing a circle and remove material also with internal rounded edge or chamfer
insert position is dragged and the final product is created(front view)
back side view
