How to edit a block with visibility of main drawing in AUTOCAD???
Small
Do it as per downward ...
And HIT the button IT WORKED.....if u see it worked properly......
    1) Select the block.
    2) Press Right Click and choose Edit Block In Place.
    3) Choose OK when the reference edit dialog-box come.
    4) Now you can edit your chosen block without Vanishing main Drawing.
  5. Step 5:
    5) For save the changes of the block, click the option edit reference and select save changes or ignore the changes select discord changes.
  6. Step 6:
    6) Then select OK for confirmation...
Please log in to add comments
