how to give centre line to oblong hole
Heres a Tutorial for you
After you have sketched your oblong hole start the "Drafting Module"
Select the "Insert" tab then "Centerline" then "2D Centerline" option
Change the type to "By Points"
Select "Arc Center" of first Arc
Select "Arc Center" of Second Arc
Change the "Extension" to make centerline pass the arc
Or "edit" the centerline and move the "handle" manualy
Complete
