How to loft the edge?
Small
Here you go ...
    Open the file, make a new 3D sketch, 2D sketch works too in this case ...
    Select the edges you want to loft then click on Convert Entities ...
    Your model should look like this; now close the sketch ...
    Click on Lofted Surface ...
  5. Step 5:
    Select the two sketches either from the model window or feature tree and click the green arrow ...
  6. Step 6:
    And you model is finished, it should look similar to this ...
Please log in to add comments
