How to make an assembly fully defined in Solid works ?
Small
To Make Fully Defined Assembly You have to make all parts fully dimensioned of fully constrained as in this tutorial. I will give a example of your components. as under..
    First of all Insert a component as you can this is fully defined because this is automatically fixed.. This can not be moved..
    Insert another component anywhere .
    Select outer surface of small pin And select internal surface of first part as in picture.
    Select concentric mate so that pin can slide in the hole..
  5. Step 5:
    Similarly select two front faces of both parts.
  6. Step 6:
    Select coincident mate so that pin can only rotate in the hole.
  7. Step 7:
    Similarly select right (or top) planes of both parts.
  8. Step 8:
    Select coincident mate so that pin even can not rotate.
  9. Step 9:
    Finely we can see this assembly is fully defined.
  10. Step 10:
    Render
Please log in to add comments
