How to purge in Creo Parametric 2.0
step by step procedure to purge in Creo parametric 2.0
Step 1: Find "purge.bat" file location
Step 2: Copy the file location
Step 3: Go to control pannel
Step 4: Search for "environment variables".
Step 5: Select edit environment variables for our account.
Step 6: Define a new path.
Step 7: Give a variable Name and in Variable value - paste the location.
Step 8: Give ok
Step 9: Give ok.
Step 10: Choose the folder location you need to purge.
Step 11: Copy the folder location.
Step 12: open cmd prompt.
Step 13: follow the steps
Step 14: Paste the file location and press "enter".
Step 15: Type "dir" and press "enter".
Step 16: You can view the files in the folder.
Step 17: Type "purge" and press "enter".
Step 18: After using "purge" command.
Step 19: Check out this video in case of doubt.
https://www.youtube.com/watch?v=NWJ_S-kMtKQ
