How to create a torsional spring in Creo Parametric 2.0
"How to create a torsional spring in Creo Parametric 2.0"
Create a spring using helical sweep command
Select the plane passing through the start point of the spring and select sketch
Create a sketch starting through the center point of the sweep section to add the angled legs
Apply sweep command on the sketch
Now create a datum plane at the center of the spring
Mirror the sketch about this plane
Now mirror the mirrored sketch about the center plane
And apply sweep command on the sketch
We have a torsional spring
