How to use boundary surface function in Solidwork
Small
Your drawing shows a confusion between sweeping and smoothing. You can scan a profile to which you give a fig 1,1B trajectory. But smoothing (2 different profiles) is a gradient of an open or closed profile to another profile figure 2A (or even a point fig 2). Only after smoothing (Fig 2b) may be added to smooth scanning guide curves (Fig 5.5A) or directions (Fig 4).
Better generally make a different sketch for each curve or profile used.
Smoothing is prefered to limit surface that
    SWEEP TRACK ALONG
    SWEEP TRACK ALONG WITH CONSTANT NORMAL
    SMOOTHING TO A POINT
    2 PROFILE FOR A SMOOTHING
  5. Step 5:
    SMOOTHING WITHOUT GUIDE LINES
  6. Step 6:
    SMOOTHING WITH ONE GUIDELINE
  7. Step 7:
    SMOOTHING WITH 2 GUIDELINES
  8. Step 8:
    A surface smoothing is preferable to a border area used primarily for closing the meeting of several surfaces cà their borders.
Please log in to add comments
