how to use DART command in NX, kindly explain how to use Location Curve option in it
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/94173/feed.png?1399213347)
![](https://d2t1xqejof9utc.cloudfront.net/pictures/files/31831/small.jpg?1389548748)
Hi siva,
see attached document to know about "Dart".
This feature is generally given in sheetmetal part to protect the part to get springback.
also u can use this feature to create plastic water bottle base.
to make Dart, u need to follow this sequence-
u can change value per u want.
to know more detail ,,see the attached pdf file.
