IronCAD - Using the Co-ordinate system to create a section
Use the Co-Ordinate systems to create a section plane. This is a handy alternative the section tool, as it does not cut the solid model.
Step 1: Create a new Co-Ordinate system
Go to the feature menu and click Coordinate system
Step 2: Position the origin
This opens the dialogue, and in the example below, I've set the point to be the middle of the upper edge of the front frame, see the green dot.
Pick this and then click the green tick to accept this
Step 3: Make Active
With the co-ordinate system placed, right click it within the scene browser, and make it active.
Step 4: Create the section
Position the system so that one of the planes interacts with your model in the desired way,
Then right click the plane and choose, "Create Section Profile"
Step 5: Edit and Examine the profile
Now the newly created section can be opened and the section inspected
