Linear cam in catia
Hello
There is the linear cam simulation in catia
Create Parts As Figure Shown
When you complete the design you have to create mechanism
First Mechanism is Point Curve Joint Between Part3 center point and Part1 curve
Second mechanism is Planar Joint Part 3 & Part 1
Third Mechanism is Planar Joint Part 4& Part 1
Forth Mechanism is Prismatic Joint Part 4 & Part 3
And add A rigid joint with your wheel to Part 3
Latest you have to chose fixed Part 1 part in mechanism
If you do all steps correctly CATIA will give you information "The mechanism can be simulated"
Here we go simulate it
