Material assignment in catia
The material assignment to the part in the catia is carried out as follows.
Apply Material:
Assign material or a custom render.
1- To apply a piece of material, first apply
material
Click on the button and your antivirus
Comes to the screen.
2-Mouse for the material you want to move
Click right and drag it onto the piece
Without assigning the product to the tree
Then the name of the goods
you can see.
Materials marked above
And click OK.
Press the button and the track below
Will receive the appearance.
Hide / Show: This command, which means Hide / Show, is in 3D space and
Sketcher also temporarily simplifies the display on the screen and the construction
To make the elements temporarily invisible, but
To make them visible.
For example,
An assembled production image
But we do not know if this hand
We just want to see the interior design
And at the same time
This practice without deleting fragments
We want to do.
Assembly
Assembly part selected
After the parts are hidden
Seen in the next image
Just as desired
Parts remain and the product
Parts hidden in the tree
Gray color.
Swap Visible Space: When you press this key, the screen turns green
You go to a different space study plane and we only hide it before
The parts are visible. In short, the space is swapped between the two space screens.
For example, if the outer casing of the engine
Environment.
For this :
1- The track you want to view
click
2- Swap Visible Space
click
3- Normal space will come to the screen and
When you click Hide / Show, the cursor will be visible on the screen.
