How to Assign VeroClear Material to an Assembly in GrabCAD Print
Assigning VeroClear material to a part or assembly is super easy in GrabCAD Print! Learn how to do it so you can start 3D printing clear materials.
Step 1: Assign VeroClear Material
VeroClear is a transparent PolyJet photopolymer for clear, acrylic simulation. It offers both strength AND stiffness. It can even blend with other materials and is ideal for see-through parts.
In this tutorial, we'll teach you how to assign VeroClear material to your parts!
In GrabCAD Print:
- Check Tray Settings: for clear 3D printing, you must have VeroClear loaded
- Add VeroClear to your Materials list
Now you're ready to assign colors and VeroClear to your part!
- Click on the part you want to apply VeroClear to
- While your part is selected, choose VeroClear material from the Materials menu
Remember, if your part is a part of an assembly, you can de-assemble it by simply un-checking the Assembly box. This will make assignments to individual components a lot easier.
Once you're done assigning VeroClear and other colors to your part, you're ready to 3D print!
