Orient and Position 3D PCB Step in Altium Designer
Altium Designer Tutorial 05: Orient and Position 3D PCB Step in Altium Designer
In this video, I explained in detail how to Orient and Position 3D Step model of PCB in Altium Designer.
This command in 3D mode (Tools => 3DBody Placement => Orient and Position 3D Body ) is used to align a #3D Body with the #PCB (e.g. the mechanical housing/enclosure), or 2D footprint, when viewing the current board/footprint in 3D. It uses 6 points to perform its function; three points selected on the 3D model and then three corresponding points picked on the board/footprint. This technique does not necessarily require snap points to have been placed since any vertex on the 3D model can be used.
if you have any questions please write me at "altium366@gmail.com".
Step 1: Tutorial 05
