Pin- Knuckle Joint Part 4
Learn, how to draft Pin, a part of Knuckle Joint, by using Creo Parametric.
Step 1: Sketch-1
Select the top plane and click on 'Sketch'.
Select 'Center Line' and draw a vertical center line.
Using the various sketching tool draw the sketch and give proper dimensions as shown in the figure below.
Click on 'OK'.
Step 2: Revolve-1
Click on 'Revolve and select the center line.
Set degree of revolution as 360 degree.
Click on 'OK'.
Step 3: New Plane-1
Select the top plane and click on 'Plane'.
Create a new plane at a distance of 30mm.
Click on 'OK'.
Step 4: Sketch-2
Select the previously created plane and click on 'Sketch'.
Select 'Circle' and draw a circle of 6mm daimeter.
Click on 'OK'.
Step 5: Remove Material-1
Click on 'Extrude'.
Extrude the sketch by 60mm, select 'Remove Material' and enter taper value as 0.018mm.
Click on 'OK'.
Step 6: Final Part- Pin
