Taper Pin- Knuckle Joint Part 5
Learn, how to draft Taper Pin, a part of Knuckle Joint, by using Creo Parametric.
Step 1: Sketch-1
Select the top plane and click on 'Sketch'.
Select 'Circle' and draw a circle of 6mm diameter.
Click on 'OK'.
Step 2: Extrude-1
Click on 'Extrude'.
Extrude the sketch by 60mm and set the taper value as 0.018mm.
Click on 'OK'.
Step 3: Final Part- Taper Pin
