Repeat Last Command with Creo Parametric 4.0
Repeat-Last-Command (RLC) utility recognize last command used in Creo and allow to you start to use last used Creo command.
Apply it with CTRL+SPACEBAR
For example: if you create a Datum feature you can crate new Datum feature directly with CTRL+SPACEBAR
or in the Sketch if you create new Rectangle and you need to create again the new one - select CTRL+SPACEBAR and you can create again last command (Rectangle).
